1 - 4 of 4 Posts
I have a Cerwin-Vega B52 setup with a Biketronics BT355 line lever.
The issue I'm having is the AMP is not turning on with the stereo consistently. I have the Turn-on switch set to VOX. Sometimes the amp will turn on 10-15 seconds after turning on the bike. Other times it takes up to 30 seconds.
Do I need to run a remote wire and if I do what should I tap in to?
Thanks in advance for your assistance.
From CV:
"The most preferred and reliable method is using the REM setting with a 12V trigger wire connected to the vehicles ignition..."
So yeah, I would do that. There was a 12V ignition activated accessory wire (maybe 18 gauge) in the harness of my Special located near the brake side directional connector- it was capped from the factory... blue if memory serves correct.
1 - 4 of 4 Posts
