1 - 4 of 4 Posts
I recently did some mods to the bike.
These included new clutch cable, and new SE spark plug wires.
I took the tank off to route the plug wire and left the tank off while I worked on the clutch cable. There were a few times when I checked the wires under the tank that lead to many things including the injectors. I move them a little but did not disconnect or pull hard on them.
So, got everything back together and now I have minor hesitation at steady throttle at almost any speed and from 2,000 rpm on up to 3500 rpm. Speeds of 35, 45 and 65.
I do have the SE Pro tuner. I plugged it in and there were no codes.
Perplexed:confused:
SOLVED.
I pulled the plugs tonight. Front cylinder plug gap was small!!! I do not recall dropping it or re-gapping it but somewhere it must have happened.
Put pre gapped plugs i have on hand in...seems ok now. Will know for sure tomorrow.
solved.
.040
1 - 4 of 4 Posts
