sanding inward and outward toward the axel, NOT in a circle around the rotor.
Thank-you, learned somin new
I have never removed the caliper to replace pads. I would loosen the lid to the brake resivoir, tape a rag around it, loosen the pins then slide a putty knife between the pad and the rotor and pryed out. Pull the pins and the pads fall out new pads slip rite in.
