Before I state my dilemma, some background.
2021 FLTRX. Screamin' Eagle oval breather, SE torque cam, S&S lifters, SE adjustable push rods, SE street canons. SE pro street tuner.
Been chasing a sound and some odd tuner numbers. I thought the high numbers were partly due to a leaky exhaust system but I checked that out and did not find any leaks.
On data run only, getting up to 6 deg. knock retard on both cylinders. Decreased timing in those areas and then got a max of 4 degrees knock retard, both cylinders. I had already finished 4 smart tune runs, and adjusted the VE tables.
Today I decided to do another smart tune run to see what the VE tables would do with all of the previous adjustments. The bike ran horribly and it seemed very loud. It was hard to tell but it seemed the front cylinder had a loud ticking, almost banging sound. It was louder than the ping sound one might get on accelerations but not a hard banging. Tomorrow, I am going to check the adjustment on the push rods and go through the process to re-adjusting those.
Any other thoughts as to what might be happening?
