1 - 2 of 2 Posts
I installed new apes on my 2011 roadglide. throttle (TBW), switches, lights, & gauges work.
bike runs great, the only problem I have is that the "Check Engine" light remains on. I ran through the DTC's no codes are displayed. Any suggestions?
In most if not all situations where the engine light is on it means that there is a DTC code and the DTC needs to be addressed and cleared. If the engine light stays on then it is an active DTC code, if the engine light stays on for a few minutes then turns off while the bike is running then it is a historic DTC. I would suggest going through the entire DTC process again it may be possible that you left out a section.
1 - 2 of 2 Posts
