1 - 11 of 11 Posts
On the way home from work yesterday, I noticed a chirping sound whenever I went over "bumbs" in the road. Nothing severe, it wasn't like I was running through potholes. Has anyone else experienced this?
Check your belt tension. A "too tight" belt can cause chirping.
Also check your muffler clamps and heat shields. A buddy of mine had the same thing, got to the point that it was scary to ride because it made so much noise. We took the slip-ons off re-installed them and retightened the heat shields, finally got it...
Check the muffler hanger brackets that hold up the rear of the muffler. There is a rubber bushing in there that dries up and can cause "chirping" noises. Just grease it up a little and you should be good to go.
Mine was a loose baffle in my slip-ons...a few turns with the allen wrench..no more "chirping" noise....Hopefully its something simple like that for you :)
You may want to check if you have a parakeet stuck between the forks and the front brake caliper. I did going to Sturgis last year, but it was dead!
+1 on the muffler clamps,.. mine still does it every once in a while on the right side.
I'll give the Virtual Mechanic Award to Stryke1. It was the rubber bushing on my right exhaust. It had not dried out but it did slide out of place.
1 - 11 of 11 Posts
