1 - 2 of 2 Posts
Has anyone been able to switch to the chirpless mode with the DIY siren on a 15? I cant for the life of me disable it using the directions in the manual :mad:
I'm having the same problem with my '12.
The procedure in the manual is:
Chirpless Mode
In chirpless mode, the siren does not chirp on arming or disarming.
The siren will still provide warning chirps and sound the alarm if the motorcycle is moved or the ignition switch is turned on without the fob present.
Switching Modes
Perform the following to switch between chirp and chirpless modes.
1. With the fob present, turn the ignition switch ON.
2. When the security lamp turns off, turn the ignition switch OFF.
3. When the security lamp turns off (but before the turn signals flash twice), immediately turn the ignition switch ON.
4. When the security lamp turns off, immediately turn the ignition switch OFF.
5. When the security lamp turns off (but before the turn signals flash twice), immediately turn the ignition switch ON.
6. When the security lamp turns off, immediately turn the ignition switch OFF.
7. When the security lamp turns off (but before the turn signals flash twice), immediately turn the ignition switch ON.
My problem is this. After I turn the ignition switch to OFF, the security lamp stays on for a second or two; but when it turns off, the turn signals start flashing twice immediately after the security lamp turns off. There's no time in between for me to turn the ignition switch back ON.
I don't know if it's something with having the DIY siren (and not the battery-backup Harley siren) or maybe I need to do a fuse-pull to "reboot" the thing or what.
1 - 2 of 2 Posts
