just make sure that the clutch lever has the tang to depress the clutch interlock otherwise you will have to shift into neutral to start your bike, even with the clutch pulled in.
most of the time, not a problem. but could be an issue if your bike decides to stall in an intersection and you're trying to get in neutral and of course, doing the 2-1-2-1-2 shuffle.....
