1 - 3 of 3 Posts
SOLD
Keep comfortable on your next long ride. These breathable Circulator Seat Pads feature 3-D construction that promotes air movement and reduces heat build-up where the rider's body touches the seat.
Designed to keep the rider cool by reducing the perspiration build-up between you and the seating surface, the Circulator Pad can be installed and removed in seconds for easy cleaning
Low-profile design minimizes seat-height change compared to inflatable pads, while enhancing comfort with its shock-absorbing construction
Manufactured of UV-stable materials, these seat pads resist fading when exposed to the sun
Elastic under-seat strap and non-slip base provide secure installation, and the available Circulator Passenger Pillion Pad attaches to the rider pad with hook-and-loop tabs
16.0" wide seat pad
Like New, no issues. Does work as advertised.
New is $89.95
$65 TYD L48
PM sent...
Discussion Starter · #3 ·
seat pads are sold, Thanks
1 - 3 of 3 Posts
