1 - 4 of 4 Posts
Issue every time I start the bike clock reads 12:00. Checked and have dc at pin 10 and 20 ignition off, and main power with ignition on anyone else have or had this issue. Yes I know ditch the stock radio but everything else works great on it and not trading for a new one. just annoying. thanks
2010 Roadglide custom
Up until I swapped it out ,I had no problems with mine.
Have you checked the fuse ?
yep checked fuses, wiring,I do have voltage where it should be just checking to see if anyone else had the same problem hate to replace it with another stock radio and have the same issue.
1 - 4 of 4 Posts
