1 - 9 of 9 Posts
Need advice on a reliable clutch setup ( hub, basket and plates) for a high torque 117" engine build... Se plates in it now with stock basket and hub, but I don't trust the basket and hub to hold together....looking at revera primo and Barnett, any suggestions greatly appreciated.. Thx guys....
I have a primo pro clutch with their VPP in my road king, it puts down 140 squared.
I also have the Rivera Primo and really like it. Based on the reviews I looked at it is a coin toss between Rivera Primo and Barnett. I think you will be pleased with either one.
Banned
Evolution Industries (Diamond Ternimator.) They make parts for Primo, AIM and more. Why not go straight to the source?
Of all the big engines we build, never had a clutch basket come unglued.
Look no father than a VPC 92T with a Barnett spring.
Scott
Barnett scorpion here.
Do yourself a favor and buy the clutch lock plate. You'll need it to properly torque the nut on the mainshaft. http://www.barnettclutches.com/clutch-lock-plate.html
Clutch grabs & holds great, hooks up noticeably better than it did with the SE clutch and heavy spring that was in there from day one.
+1 on the Evolution. Flawless in my build, 2 other big inch builds my mechanic did that are 140+HP have the same result...very nice clutch.
I run an Aim CF2 Second Generation.When you get into the big horsepower it just makes sense to run the good stuff.They are alittle expensive but broken cranks are even more expensive.A cast aluminum basket is a disaster looking for a place to happen in a big horsepower build.
Thanks for the feedback, guys....I ordered the Scorpion, due in Monday....
1 - 9 of 9 Posts
