Ok 2013 RGC on my current build I got extended clutch cable due to new 16inch bars also took apart the tranny to powdercoat the cover. Everything is back together. Now once the bike is all warmed up neutral is impossible to find and the bike pulls forward hard with the clutch lever pulled in. I adjusted the cable and it's still happening. Any idea what could be going on?
Masque
Maurice, try adjusting the clutch pack.
Make sure there is plenty of free play and that the bike is cold when you do.
The cable is only for taking in the slack.
Mike U.
I always collapse the cable all the way before adjusting the clutch pack. Then you can watch the hand lever to see when it bottoms out.
