Anybody using the Cobra managment system? I'm looking at the one which is closed loop utilizing the o2 sensors. Any comments pro or con? Thanks. Oh yea, bike is '08 Glide which will have true duals and Rush slip ons.
I have no personal experience with this product but it sounds like the terry components Tv3 which ive heard good things about. I think a tuner like this is good if you will never do much more than exhaust, air cleaner and maybe small cams. I think if you plan on making serious power at some point swapping out the throttle body and injectors you will want something that replaces then 02 sensors like a PCV autotune or thundermax. I really see that as the only disadvantage with a unit like this so it depends on your goals. Personally I plan on going pretty big and swapping out everything so I will be getting a Thundermax. It's pricey but I like the fact it replaces the ECM.
