Ran a diagnose just for the hell of it. This is what I'm getting.
P: PN 159P 003-
S: 61121, 61122, 61126, 61155, PN 68924-07
SP: PN 67261-04A
T: PN 67459-04A
Where can I look these up, google isn't helping on my phone right now.
There is a sticky in the troubleshooting section of this forum that has the DTC's.
Discussion Starter · #3 ·
Seen it but they are all a letter and four digit codes. (ie: L1234)
I don't think those are codes. Those I believe are part numbers. Engine codes will start with a "P"and followed by up to 4 digits, ie P0000 up to P9999. Other system codes may have a different letter but will have similar numbers following it
Discussion Starter · #7 · (Edited)
Okay, I was under the impression during the diag mode, it will only give error codes.
So, those part numbers are parts I need to replace? I also just read that the "6" in the codes could be a "b". Which make sense.
61121 = B1121-Left turn output fault (TSM) or left turn output open (HFSM)
61122 = B1122-Right turn output fault (TSM) or right turn output open (HFSM)
I know the right turn signal isn't blinking up front and the bulb works, but it does blink in the back.
61155 = B1155-Neutral switch input short to battery
I have no clue where to look for this issue.
