1 - 3 of 3 Posts
Okay, so I've read that some have had issues with the front plug wire rubbing on the tank of the 15's. Whereabouts is it rubbing at? I checked mine today and found a rub mark an inch or so above the plug boot, right at the tunnel edge of the tank. Is this the spot that folks are referring to or is there another spot under the tank?
Lil Chief
granted this is an '03, you'll find without a tank lift or positionin the wire away from clamps it will rub!, left the tape on mine as a reminder, many years ago
Got it. Thanks reds4!
Lil Chief
1 - 3 of 3 Posts
