thanks Franky, I did want to see where people are putting besides the fairing minimize the air hose length. If you can fab up a section under the seat.
Thanks again
E9 turbo
Mine had to go in the fairing due to ABS. It appears to be the cleanest location. If you put it in a saddlebag you will have to have a way to disconnect it when you remove a saddlebag. I don't think there is enough room under the seat or gas tank. You could possibly put it in the tour pack but if you ever decide to make it removable you will have to relocate it again. Good luck.
