1 - 2 of 2 Posts
Installed SS PN4.520d took bike out yesterday for a ride
Today I start bike and get a crackling sound from speakers, pull aux plug tried CD, same crackling, turned Off radio, still crackling through speakers.
no rain, or moisture
When I wired hi input wires I did ground middle ground wire to bike bolt by fairing bracket.
Didn't crack yesterday amp is digital so what do you think the problem is coming from.
Amp is grounded to frame close to battery using 8 gauge.
When bike is not running sounds fine, when running with motor vibration then comes the crackling sounds even with radio and speaker switch off.
Wondering if its comming from the his lights?
Discussion Starter #2
Tracked it down to the HID lights from SoCal. Put in the replacement wiring upgrade and the wires pulled causing flickering in bulbs which crackle speakers, put old wire in no more flicker, but there is still a him going to amp even with head unit off, will have to live with it for now.
1 - 2 of 2 Posts
