1 - 17 of 17 Posts
Does anyone know if the Fang spoilers on the 2019 CVO RG can be fitted to a 2018 RG Special. I heard it will fit if you buy the chopped highway bar and new fairing mounts...want to be sure.
Do a forum search. There’s another thread on here where quite a few guys have done this already.
When you buy the HD mustache engine guard it comes with the new fairing support and then yes you can install the Fang Spoilers. I bought my engine guard from Surdyke and saved some money and you can get the spoiler from them as well for almost $50 cheaper than your local shop.
I have one that I installed on my 2018 RGS and it fits just fine. You will need buy also buy the chopped engine guard to mount the spoiler to and the OEM engine guard would be in the way.
I have the spoiler WITHOUT the engine guard or extra supports. Everything is solid.
Let’s see some pics. I’m interested to see how this looks.
I'd like to see some pics of this as well.
I don't need pics. My concern is that if you do not run the rear fairing support brackets you will be asking for trouble down the road. If you put all the weight of the fairing on the main brackets the vibration of the bike and just hitting bumps from normal riding will cause stress cracks and eventually break the plastic fairing up front. There are a few good choices of hidden fairing brackets that you can run and not have to worry about this.
I was more interested in seeing it due to the fact that everything I've read about it says you need the shorty highway bar for it to work.
Not sure how much support two plastic nubs clamped to a crash bar are going to give the fairing.
The Fang Spoiler fairing I'm not that worried about. I was referring to the support brackets for the Road Glide fairing that mount to the stock engine guard. If you do not support the back of the main fairing you will run into issues down the road. If you are running that support piece that comes with the mustache engine guard then you are fine. It can be bought separately.
The nubs on the spoiler use rubber P clamps that wrap around the chopped engine guard. Mainly that is to help (I believe) keep the fairing from wanting to flex or shake. With your setup, the bottom cover is pushed into the rubber grommets on the oil cooler, then bolted to the left and right side pieces and then those are bolted to the bottom of the fairing. I would be concerned that, in essence, the entire lower half of you spoiler is counting on the 2 plastic nipples to not pop out of the rubber grommets.
Like has already been said, the main thing for the supporting the fairing is to use the upper, hidden bar that comes with the chopped guard. That way you aren't just counting on the 4 bolts at the neck mount to hold everything.
I went in yesterday to ask about the support bar that comes with with the chopped guard. The parts guy was a bit confused but told me the support bar itself was $170 dollars. That doesn't seem right since the whole kit is $299. Maybe someone else could see if there is a part number for the support only. @crazy4ink
Found it at Surdyke.com for $140 part number 47200354. Anything over $149 is free shipping.
https://www.surdyke.com/PartsMain.aspx?PartNumber=47200354&SubCatID=&CatID=&Name=&CatName=
He quoted you the right retail price.
1 - 17 of 17 Posts
