I believe that there is a relay that can be removed that will disable the power locks but I'm not positive.Anyone know how to disconnect the power lock assembly from the lid?
I have the owner's manual, not the service manual.I believe that there is a relay that can be removed that will disable the power locks but I'm not positive.
Do You by chance have an OEM Manual for Your Year CVO?
Mike U.
Are You just trying to eliminate the Power Locks or is there an issue with them that You want to correct?More specifically, I am looking on how to disconnect the power lock actuator from the lid.
The latch screw seats behind the actuator, I want to change the screw but need to remove the actuator....Are You just trying to eliminate the Power Locks or is there an issue with them that You want to correct?
Mike U.
Oh okay, I am not too familiar with the Power Lock Actuator if I can find any pertinent info I will post it here for You.The latch screw seats behind the actuator, I want to change the screw but need to remove the actuator....
