1 - 3 of 3 Posts
2016 rgs - Will have to travel to get my bike flashed 4/0. Is this overkill until I can't get flashed? Will I degrade my signal?
2 amps (4180/2180), 6 speakers (4 BT 6.5, Pioneer Pro 6x9). Plan is to run everything off of the OEM 6.5 HU using bt355 and a series of RCA "Y" connectors. Splitting signal to 4180 (front/rear) and further spitting to the 2180. I have bt355 for the rear channel once it gets flashed.
Give Biketronics a call, Mike has developed a flash module for their customers that allows you to flash the radio yourself. You can either rent it or buy it from them. I just installed one of their amp and speaker kits and used it to flash mine and it works great.
I have the BT 2180.15 set up. I'm not flashing my system. it sounds perfect with the line levelers alone. You may need to. But setting it up first you may not. Unless you need to change it to 4 from 2.
1 - 3 of 3 Posts
