1 - 15 of 15 Posts
Anyone have info of what tool is used to De-pin a wire out of the HD disconnectors and where can I get one?
Discussion Starter #2
These are the types of pins that I have to remove from the connector.
Do a search on the forums. There is pictures and instructions. Use small pick or paperclip from the back side of connector. There is a tab on the pin side you have to pop up first. Its been a while since I did it .
Dark, Here's the pic of the connector. It's for the saddlebag lid LED spoiler.
For some reason I can't see the picture but more than likely like what shermanator said is that there's going to be a lock, remove that and use a small flat tip or a paper clip, you should be able to see a little tab that you have to either push up or pull down and the pin will release from the back side of the connector. Someday I'll have to do a diy on how to de pin connectors as I was a wiring tech.. I've honestly never had to buy a de pin tool.
A dental pick usually works pretty well. You can pick up a set at Harbor Frieght for about $5.
Lil Chief
ADD: You might have to remove that white piece in the middle of the connector first before you can get the pins out. That should pop out of the housing if I remember correctly.
Reactions: RGKen
I put the darn thing together but now I need to replace the wires and can't get it back out I put the darn thing together but now I need to replace all the wires and can get them back out.
I'll try you guys advice
A small really small allen wrench will work and most people have those in there box.
Discussion Starter #14
Thx. I'll try this evening
A filed flat paper clip ( larger size) works fine once you get the knack of using it in the right place. You have to depress the reverse out pin.
1 - 15 of 15 Posts
