I need the site knowledge for this one; I bought a dark custom derby and cone cover today. I went to put the derby on and realized the derby cover bolts are torqued to 100lbs? the snap-on T27 I used about broke. Does this need to be so tight? I F-ed the bit up and the bolts are trashed. Before I torque the new bolts I bought , do I need to be so tight?
this is from my 01 manual
Using a T27 TORX drive head, install five screws (with
captive washers) to secure clutch inspection cover to the
primary chaincase cover. Alternately tighten screws to 7-
9 ft-lbs (10-12 Nm)
Eagle
100lbs???? Not right, most car crank pulley's aren't torqued that tight. 7-9lbs sounds right for the '10's. Just good and snug will get you covered, or if you have a service coming up (1,5,or 10k) the tech should swap them out for you for no charge, and that's because the old derby cover has to come off anyway
· Premium Member
after you get the bolts out, before putting them back in (whether new or same) put a dab of anti-seize on the threads. this will save you problems in the future.
