1 - 11 of 11 Posts
15 RGS
Rear Fender ends above Tri Bar.
The Tri Bar is mounted to the bottom of the filler sections, that run along each side of the fender connecting in a U at bottom of fender.
When driving thru water, etc. dirty water seeps thru the seam between these two sections.
Any one have a solution that works ?
15 RGS
I like the idea of that. What size foam you use? I'll go get a big roll of it Monday
Yep! It's call a pocket of quarters and a trip to car wash! :wink:
Don't worry I been taking my 08 to the $.25 car wash since it's been new and I never had a problem, just don't get the wand to close to the bike and take the finger off the trigger when doing the instruments.
Discussion Starter · #7 ·
Thank you for input to date !
Any other thoughts ?
15 RGS
Don't you get water around the Tri-Bar too? I'm thinking of rebuilding with clear silicone everywhere...
Discussion Starter · #10 ·
As a Jetski guy, my first thought was the removable marine silicon.
#4100 or 4200. Ones removable, one is permanent.
I put up original post, to see if others had come up with a different solution.
This bump may prompt other responses.
I replaced original Tri bar with the LED Custom Dynamic's version. No leaks from it right now.
Gone But Not Forgotten
Yeah, that :smile:
1 - 11 of 11 Posts
