1156 is a single filament bulbWanting to change out front and rear bulbs to LED but not sure which type I have. .. 2013 fltrx
You may consider checking out Custom Dynamics for their LEDs and they will be upfront with you about if you would need a load equalizer.Will I have to put a load equalizer or resistor (which ever it is) to keep blinkers from hyper blinking?
i have custom dynamics led clusters front and rear on my 2010, and a load equalizer was required.Will I have to put a load equalizer or resistor (which ever it is) to keep blinkers from hyper blinking?
So you ran them on front and back without resistor?+1 on calling Custom Dynamics the 2015 CVO had 1157 in the front and 1156 in the rear after installing LED's had to run the four way's for 15 seconds to rid the "quick flashing" issue
The Rushmore bikes(2014 and up) are different than ours (2010-2013). He is referring to his 2015, yours is a 2013.So you ran them on front and back without resistor?
this doesnt work on bikes 2013 and earlier+1 on calling Custom Dynamics the 2015 CVO had 1157 in the front and 1156 in the rear after installing LED's had to run the four way's for 15 seconds to rid the "quick flashing" issue
