2011 FLTRU
Stage 1 AirCleaner + Rinehart 4" slip-ons. Runs pretty strong (seat of pants dyno) with a very minor decel pop around 1900RPMS. Runs a bit hot at a couple of RPM ranges, but nothing intolerable.
I want to put in a decated factory 2-1-2 pipe just to reduce the heat some. Will I need to reflash the ECM, or get a tuner?
Thanks in advance for advice.
When you added the air cleaner,you needed a tuner.If you had done either the exhaust or a/c,it wouldn't have needed one,because the airflow through the engine wasn't significantly changed.
the only flash I'm aware of is the "stage 1" download,which most have said is a waste cause it's still EPA lean.
Discussion Starter · #4 ·
PO said they had this done already with the stage 1 and pipes. This may be why I have the minor pop, and also could explain the brilliant blue headpipe!
Looks like a tuner is in my future.
2019 RGS
That download they do is a waste of money. Get a tuner or the SERT and have it tuned. My 05 I did that. Ruined a set of pipes. They glowed cherry red.
