1 - 20 of 62 Posts
All,
I've seen a few posts on here about how to install the SG Rear Fascia, which gave me the confidence to try it myself. I took care to document each step and thought I would post as close as I could get to step-by-step instructions. I have this available as a PDF file also (if interested PM me). IMHO - the rear looks so much better with the rear fascia. All told, less than $200 in parts (thanks PC PAIN) and a few hours of time to install and document.
I'll continue posting subsequent slides in follow-up messages.
Hope y'all enjoy!
Cheers,
G
Page 22 - Parts List
Page 22 - Parts List...thank you for your kind attention! Hope this helps some of you improve the look of your ride!
Cheers,
G
Very cool! I didn't realize it was that cheap to do it. I would like a copy of the pdf. I'll PM you my address.
Thanks for doing the legwork!
As an FYI, if you are averse to drilling holes in your fender. Get some 3M double sided automotive adhesive tape. It is a royal pain to line up and stick, but once you do it is not going anywhere ever again.
PM sent, thanks!
Discussion Starter #16
Good point OldNerdGuy. I debated on the 3M tape ... ended up going for the gusto. Ha! Good option to mention for others who may be less confident drilling their fenders.
Cheers,
G
Discussion Starter #17
Important notes - added to PDF
I've added this to the PDF, but wanted to mention to all these words of caution if you decide to drill your fenders...
Use a centerpunch to keep the drill bit from walking and make sure you use sharp bits. Also - put a scrap piece of wood between the fender and the tire for when the bit breaks through.
Cheers,
G
1 - 20 of 62 Posts
