Here's the dyno from a touring build that Frank did for me. Includes S&S 106, Dragos 580 cams, ported throttle body, and stage 2 heads. I chose to keep my true duals and kept a modest compression with a.040 gasket since most of my miles are 2 up touring. I asked Frank for 100 hp and 120 ft/lbs and he delivered as usual. Here's the dyno.
Frank was telling me a cage was nice enough to pull out in front of you.Sounds like you came out better than the bike,which is always a good thing.Hope all is well with you.The bike can be replaced they make em' everyday.
The dyno chart is in the dyno section. The thread is titled Dragos engine build.
