For those of you that have done this before, I need some advice before I do mine. I just received my tour pak I ordered from Horny Toad HD. I got the Air Wing tour pak lid rack that I need to mount on it. The instructions with the rack say to set the rack on top of the TP lid and center it and mark around where the mounts touch the lid. Then put masking tape over those spots and mark again on the masking tape, then drill with a small bit first and then drill again for the final size hole. I'm so anal about stuff like this that I'm not sure I'll get it exactly centered the way I want doing it this way. On the inside of the lid there are already marks that are centered and line up perfect for the rack. Is there any way I could drill from the inside using a very small bit without flaking or cracking the paint on the outside and then finish drill with the final size bit from the painted side? This would really hurt my feelings if I screwed this up.
