I have an 11 FLRTX.
I installed new handlebars and farkled up some wiring. I have re-wired everything and replaced parts that I messed up...what a debacle.
My turn signals and brake lights aren't flashing although they are getting power because they do run as running lights. I already replaced the front brake light switch also in case you were wondering.
I have DTC U1016. I read in the sticky that it has to do with the ECM (at least that's the case for the 2010's and I assume it is the same for the 2011's).
Is this something I can fix, or do I need to schedule a trip to the stealership? Please help.
Did you try to clear the code ? If you did clear the code and it keeps coming back you will have to take the bike into the dealer to have the ECM reflashed . The sticky on how to find the DTC's also tells you how to claer the codes . It sound like the TSSM may need to be married back to ECM . The code info is a nice tool but as always there are some things we can fix at home and some things we can't .
These codes could also cause the U1016 code to come up U1040;U1064;U1097;U1255 . The DTC's should be analyzed from the lowest code to the highest code & sense all of these are related to serial data error I would recommend have the dealer look at the bike .
