2011 FLTRX; SE 254E; SE AC breather; 2-1 Fat Cats and SE race Tuner.
Very nice looking curve and not bad numbers. Your actually running fairly lean a/f for a WO pull, and could possibly gain some if you were closer to 12.8 or 13.0 to 1. Make sure your not pinging at WO throttle running that lean.
W
Guest
That was the issue with mine having the A/F to high and thus running lean. Mine was running as high as 15 and as low as 14. Once Travis my tuner adjusted it to the upper 12's to 13 I gained 5+ HP and just under 5 lb's of TQ. You still have some room to improve your numbers. Mine also runs cooler now.
