161 - 180 of 786 Posts
You are correct, but cam is smaller than most cams people are installing.
This is a great bagger 2 up cam that most should have with their riding style, but they are too stuck on wanting the bragging rights and numbers.
No doubt. I just upped mine to an Andrews 485 from the RS468 with the intention of adding the 128” kit next year. And the wife wanted her bike to sound like mine. So it made sense to upgrade mine now and put mine in hers. Saved me some time and money down the road.
There is a noticeable difference in the cams.
Discussion starter · #164 ·
Bone stock 2023 CVO Road Glide
Same bike. The only change being the Extreme Wedge Air Cleaner.
Both bikes are the stock map / ECM map with no tuning changes at all.
Discussion starter · #170 ·
The true duals killed the HP on this one but the customer wanted the Vicla look and wouldn’t let me change them.
Reactions: grwil67
Discussion starter · #173 ·
Wow, never would've thought you'd see that much gain with no other changes. Are the newer bikes restricted even more for EPA than my 2018?
Yes they are restricted a lot.
Awesome tunes and you are killing it!
You got the squeeze down right on the big bores amd the Andrew's 554 and pretty much the S&S 475 down packed on ANYTHING!(y)
Discussion starter · #177 ·
2017 Road King 107 to 128, Andrews 554 cam, SE ported heads, 64mm throttlebody and manifold, 5.5 injectors, Khromewerks headpipes, mufflers and louvered baffles and the new extreme wedge air cleaner.
^ that's like adding another bike's power to what you already have. Must be night and day difference.
Reactions: crazy4ink
THAT HAS TO BE INSANE @ the difference!!
So am I correct in saying that he (#177) has all of the screaming eagle stage 4 128" kit, other than the Khromewerks headpipes, mufflers and louvered baffles and the new extreme wedge air cleaner??
Looks like this Andrews 554 cam works for you in just about all of your big bores!!!! (y)(y)(y)(y)(y)💪
Question
Why did the Fast Johnny (#167 @ 149/160) kick ass compared to these other 2 HD stage 4 packages in last few day?? Is it because of the name and paint scheme?👀🤣👻
