I am curious, would an easy start cam eliminate the need for a comp sprocket?. I am gonna put in s&s easy starts this winter (08 103 w/ 255, no comp release), hopefully, to go easier on the starter and compensator. Maybe go with a vulcan or game changer. Just have a very basic understanding of engines. Any insight would be helpful. Attatched pics of comp...ok or nay. Can you tell from just looking?
Happy Christmas and Merry New Year!
Eric
an easy start cam eliminating the need for a compensator sprocket? not sure what that means.
it lifts the exhaust valve, which lowers compression, in order to make it easier to start.
not quite sure how i feel about more parts moving around in the bottom end of a motor...
https://www.youtube.com/watch?v=5q5mg0C4Rfg
The compensator absorbs engine pulses when running. The easy start cams make it easier to start. Neither would benefit from the other or vis versa.
The easy start mechanism is fine. It only actually moves once on start up and once at shut down. V-Rods run a similar mechanism. And the Easy start cams crank with less effort than non easy start w/the oem compression releases. I just pulled a set that have more than 20K on them, and there is no detectable wear on the easy start lever.
If I was buying a cam set from S&S, I would spend the extra $ for the easy start.
