1 - 4 of 4 Posts
Anyone purchase the Black LED tail/brake/signal light bar/wrap for PRE 14 tour packs? I see them all over ebay from $50-$150. Clearly these are knock offs of the HD stuff, but look the same. Anyone purchase one of these to replace your stock existing Ultra Style Tour Pack light bar? Just curious if it's just plug and play, remove my existing light bar/wrap and this one bolts up directly and plugs into existing wires in my TP or is there more to it (as in load equalizer) and for anyone that has replaced stock with one of these, do they line up exactly so as to not leave any marks from the stock set up? Thanks.
A friend has one on a knock off tour pak and you cant tell the difference between a real setup or his knockoff. I am pretty sure it was plug and play and looks to be exact as for shape.
N/P man....I myself have 45 dollar knockoff lower fairings, and you cant tell the difference at all except my vents actually work better than my oem ones.....
1 - 4 of 4 Posts
