EITMS is not working. I went into the PV software on my computer and added a 1 which was supposed to enable it. Reflashed it on the bike and still doesn't work. Button on PV in the tools is still disabled. Thanks for any help.
you should be able to enable it on the bike independent of the pv. just roll your throttle forward until the cruise control light flashes green for active, orange for inactive.
Thanks for the help got it working. Any suggestions on what temp to have it turn on and off at?
so what did you do to get it working? i'm sure others would like to know also.
my stock map settings are on at 284* and off at 275*
I went into the environments and changed the on to 280 and off 260. Was just a guess for numbers on my part. Numbers that were there were super high and it never would have worked. Thanks again.
