2017 road glide ultra. Bought from harley electra glo filling lights keystone. All went well hook up was simple disconnected wire harness on rear fender and put in y harness and ran to lights .
Turn power on all lights ok but filling lights not on . Any suggestions. There is the relay and one spare connector.
That spare connector should go behind the right side cover (throttle side). There's a connector there for it to hook to. I'll find a pic.
Thanks will look at it as I looked in side with fuse panel and nothing there . Never thought to look at throtle side . Will let you know if works . Thanks again
You're welcome. On 16 and earlier it does go on that side (with the fuses), but 17 and later is on the throttle side.
For model years 2017-later: Route the wire under the motorcycle's tube frame to the caddy containing [325B]. Mate the 3-way connector to [325B] under the side cover. Install retainer clip provided onto kit harness 3-way connector. Install the 3-way kit harness connector by replacing C325 connector cap.
HI jimbo
Just wanted to say thank you lights are hook and on . Thanks for answering question not saying how easy or simple it is and that anyone can do it . Thanks again Peter
411936
