.......ok so im in the mist of installing some Heated Demon grips on my RG and while pulling out the harness on the r/side of the bars, 3 wires from the throttle control came out of the plug (224B) now there are 2 sets of red, black & white wires coming off of the throttle control, the other red black & white wires was still connected once i got the harness out, so i know where those match up to on plug (224A) red, violet & grey. So the red, black & white wire left goes to the brown, blue & black on plug (224A)
I have the electrical & shop manual and they both show the wires coming off of the throttle control as violet, blue, red, brown, grey & black. I was that was so true then i would have figures this out by now BUT the colors coming off of my throttle control are not those colors, what idiot made these books !!!!
anyway Thanks for any help , as you can see im removing these plugs from my bars , they are to tight in there and caused this issue !
Discussion Starter #2
As you can see in this pic the Sensor twist grip ( i call it the throttle control ) has a plug with a blk & wht wire (with 5/7 and a line to it) and then the other 2 harnesness both have the red, black & white wires in them
If no one gets you help before 1600 , I have the colors written down at home.
Yes, they are idiots who write these manuals anymore , but the grammar and punctuation are spot on. :eek:
Thank you Mray81 just by looking at that pic i believe that its going to solve my issue , i will attempt to get some work done on it today to see but its my oldest bday today turning 21 and we are supposed to hang out BUT daddy wants to play with his toy lmao, ill let you know
Thanks once again Mray81, everything worked out great, rode her today to the international motorcycle show in NYC this weekend and needed the heated grips and they do work great.........good looking out !
