1 - 4 of 4 Posts
Coming home tonight I notice that while in sixth gear, the 6th gear light isn't on. Then the light & engine light come on. Uh oh. I look at my gauges and see my volts gauge pinned at 16! S**t. I slow down and the volts drop to 14 and the bike works again. But any hard acceleration and it happens. Again and again this happened as I limped home.
Before this happened I was white lining it in heavy NY traffic. Couldn't tell you what my gauges were reading as I had no time to look at them.
Anyone know what it means when the 6th light goes out, then come on with the engine light? I know it's concerning electricity, but that's about it.
I had this happen a few weeks ago. A little research here showed others having this issue and it ended up being a bad voltage regulator - a 'known' issue that is covered under warranty. I went in and had it looked at and they replaced the entire voltage regular and associated parts. While there they also diagnosed a funny noise in the primary (which I didn't even hear/notice) and they replaced that as well, also under warranty, also a known issue. My warranty is up in two weeks - or it was going to be... I just reupped if for two more years!
There has been issues with the voltage regulators. I believe there was a recall on them or at least a service bulletin about it. Let a dealer run your VIN to see if yours was one of the bikes involved
Spoke with Harley. The recall is now expired. But my bike wasn't in it anyway. They think the same as above that it is the regulator. I go tomorrow.
If I ride slow, which is very hard to do, I should be okay to make it to the stealership. Thanks for the info.
1 - 4 of 4 Posts
