1 - 2 of 2 Posts
Been reading on here for a year or so, and suddenly, the light went on. I used to work as the Final Test Engineer for an industrial Diesel Generator company. Wiring Harnesses were a pain. Here is the link to the tool I used to pull apart, and put those tricky suckers back together. Made my job easier.
The LADD DT/RT1. A screw driver with a little hook on one end.
http://www.electricalhub.com/deutsch-dtrt1-dtm-series-removal-tool
Thanks Rob. May try one out. I've been using a hair pin with the little end pulled off. Works pretty good but a little to flexible at times. Is it too early for an annulment?
1 - 2 of 2 Posts
