1 - 4 of 4 Posts
What is needed to put enforcers on my 12 road glide. I know I’ll need to use the non abs bearings but do I use my stock rotors or the 14+ rotors and in the rear will my stock pulley Work?
14+ rotors will be needed for the front. Rear rotor and belt pulley are the same. I would change out all the bearings and not just the abs side.
they will bolt on no problem provided the bearings and spacers are a match to your bike, meaning ABS or non ABS bearings and spacers. also you will need the brake rotors for those wheels. and yes your rear pully will work with the enforcers
FWIW, before I traded up for my current '17 RGS, I had a '13 RK that I put on dealer take offs from a '16 SG. They only thing they had to do was put on the appropriate non-ABS bearing and wheel spacers.
1 - 4 of 4 Posts
