1 - 3 of 3 Posts
Hi folks,
I have a question here: any of you have stage 1/ above ( cams etc.) or mufflers/ fuel Managment like SE racer tuner AND extended warranty?
I have a 2011 RGU still under factory warranty, but I plan to do the extended warranty right after the original one expires. Te question is: I know from the dealer and reading around here that anything you do to the engine: i.e. Change cams, install HD race tuner wont be covered.
Any thoughts?
Why not go with PCV and if something craps out. Put stock AC, muffs, and take PCV off. Then take to dealer for warranty work on motor if needed. The idea I got anyway.
1 - 3 of 3 Posts
