Picked up the bike last night and ran it for a bit to get the oil up to temp. I'm at 5000 miles but I need to hold off on doing my full 5K service (you'll find out why soon). I did need to dump the engine oil to make sure I had some more of the break in oil out of the motor. When I drained it, I put my typical Bel-Ray back in. They come in liter bottles instead of the typical quart sized (not sure why as it is an American company I believe).
Three bottles into a hot engine after letting it drain completely for well over 30 minutes gave me a "cold level" of this (bottom of hot vertical). It was on the lift in vertical position. I figured that would be about 3 dots up when it was hot on the sidestand. Anyone else typically use less than 4 quarts worth when doing their oil changes? Just seems like all of my bikes run way way way lower on oil levels than everyone else.
