1 - 2 of 2 Posts
I have a 2016 Road Glide Ultra. Just had my 1000 mile maintenance from my dealer last week. I put about 100 miles on it yesterday, and was doing some cleaning on it afterwords, and decided to fill it up, started bike, and oil lamp came on. I called my dealership, and he said if I was not hearing obvious clanking with the engine, it was probably a faulty sensor. My oil levels were full by the way, which I told him. I did hit the info button, and oil pressure was at 18 when idling. Any thoughts about the light coming on.
You should take it in and have the sensor tested. Most likely that is the issue . Better safe than sorry.
As far as 18 at idle , how hot was it , was it in parade mode all important questions.
Most if not all modern engines use low draw oil pumps. They run at lower pressures .
1 - 2 of 2 Posts
