I'm currently riding a 2013 CVO Road Glide. The 110 is stock with a TTS Master Tune and I'm running RB Racing Pipes. I also have a 2008 S&S 117 EVO (carbureted) with Branch O'Keefe heads and Cams. It's currently in my 96 Fatboy and the bike is POWERFUL. The S&S hasn't always been reliable but I think a higher torque starter will fix the problem. I'm considering a swap. I'd like to know what modifications I may need to make to do the swap. Any advise to help me make a decision is also appreciated.
Build the 110 up. Leave the Fatboy alone.
Why would you consider a swap?
Agree with Big_gary...use the 110 as your platorm. A lot of good engine builders sponsor this site...I'm sure they can provide you good information. JMO
+ 1 on the previous posts.
The 117 S&S will not work in the RG. The reason why is the motor mount location are different on both engines.
The RG engine is a "A" style engine and the S&S engine is a "B" style engine. The "A" style engine is used in all touring models and the "B" style engine is used in all softail models.
Also the trans bolt up different.
Building the 110 is your best option.
Discussion Starter · #6 ·
Well, it looks like there's no decision to make. The S&S stays in the Fatboy.
If that starter(or starter clutch)is in need of attention, then perhaps the electric release's are not working properly.
That 117" can easily produce 125-130/135-138 in very tame form, if wanted.:)
Scott
