Has anyone experience a Diagnostic Error Code U1016, Loss of ECM Serial Data? If so, what's the cause and corrective measure? Thx.
That's a loss of serial data.
Fuel Moto has a post on their site about Harley Codes and how to reset them.
Harley Codes - Fuel Moto
Hope this helps.
Best of Luck.
Mike U.
Q-Hog from what I've been reading people are saying that the Thunder Max is causing it.
By chance, are you also running a Thunder Max on yours?
If so, I believe Thunder Max states there's nothing to worry about it's just the difference in the ECM and The Thunder Max.
Mike U.
Thx. I am running TMax.. I heard something regarding that but I wanted to see what the great minds of the Tank had to offer.. Can't beat what this forum has to offer..
It most in likely not the T-Max. I would suggest changing the battery in your FOB. When the ECM doesn't read the FOB correctly because of a low battery then you will lose serial data and get the code U1016
