1 - 19 of 19 Posts
Afternoon everyone.
Bike is a 13 fltrx fuel Moto A/C, was a cat less oem head pipe, power vision with map from Jamie at FM, Nasi CFR mufflers
Changing my plugs and getting the glide back together in prep for a Dyno tune since I couldn't get rid of the high load/ high rpm detonation from last year. Front plug was missing a small chunk of porcelain, guessing from the detonation, so I put a bore scope down the hole and can see an excessive amount of carbon build up and what looks to be some that had been breaking off. Only a couple hundred dollar scope so not the best image but other than the carbon it looks ok. Not as much piston wash as I'd like to see, but it's getting a better tune soon, hopefully. My question: Is there any way to remove some of this carbon build up or should I not worry to much about it? I don't want it to affect the Dyno tuning process by having it causing detonation while he's trying to tune. Can I steam them off with water spritz through the intake? Apologize for the long story. Just want to be thorough for all you experts to be able to better help. Thanks in advance.
My top end is apart right now. I used oven cleaner and some gentle scraping with a screw driver. My carbon was on there thick. I'm attributing most of it to the head vents venting into the intake. I'm going to route my breathers down into a catch can with a return line to retain vacuum like stock. Some guys dump it strait to the ground.
I've heard that Sea Foam makes a product that you can spray into the intake. I'm not sure how well it works but maybe if you did a session and scoped it again. If you could see any metal with the scope you are doing better than I was. I have close to 50K on my motor and aside from the carbon build up everything looks new still. The cylinders still have the ball hone marks. I think I may start using sea foam at the same time I do oil changes. I hear they make a good additive for the oil as well to clean out the motor sludge.
Afternoon everyone.
Take your a/c filter off, warm bike up, then take a spray bottle with water in it. What you want to do is idle up to 1500-2000 rpms and spray a fine mist into the intake. Make sure to keep idled up. If you over do it the motor will try and idle down to much. If you do this, the hot steam will clean the pistons off very nicely. Do this for 4 or 5 sprays then let it idle and blip the throttle a little. Do it some more the same way with the spray. You will be surprised how clean your pistons will be. This is a trick that has been used for years on Harley's and car engines to clean carbon off. From what you said about your plugs, it sounds like you've been running lean which could be lending help to the pinging and pre-detonation. What causes the buildup on the pistons is the breather tubes from the rocker boxes going into the intake track. I've got mine run to the outside air, no drip can. This will keep the excessive build up on your pistons. Good luck
Edit: All bike engine pistons on Harleys will look like yours without the breather tubes run to the outside air. Nature of how Harley did it.
I had the same problem with my Dyna it ran like crap!the carbon would get hot and ignite fuel prematurely. sprayed sea foam into cylinders and I let it soak and repeated the process for a week or so it was winter.mean wile figured how to vent pcv to the atmosphere. Ran the bike and sprayed sea foam into the intake.wow what smoke.now before taking it for a longer test ride I changed oil installed new properly gaped plugs.wow it was like new. Carbon can realy make you bike run crappy.Good luck!
Here's a pic of my 06 pistons after 13,000 miles with SE slip on's and a high flow HD breather.
Thanks Smarty. I think I just found a new thing to do every 5000 miles. :grin:
Is there a particular type of sea foam to spray in the hole? How much? Did you crank it over without plugs to evacuate before trying to fire the bike after a week of soak time?
I agree smarty, I think it was running lean. I tried a few adjustments with the power vision, it was late in the season and would only ping in a balls out trying to race crotch rockets situation so I wasn't too worried about it. Anyway, that's why I decided to get it professionally tuned before the season starts. I think I'll try soaking the Pistons with some seafoam as suggested by Dozer then try to steam them off. Do you have any pictures or a link to the kit you use to run the breathers out of the A/C plate?
If your bike isn't torn down, using spray with water works just fine. Has been done this way for years. On the vent, with the stock breather, I took the little s hose off the tee and put about a 3' section on it facing up and then drilled a hole in the backing plastic on the upper front side smaller than the hose and pushed the hose thru. I then ran it over to the frame a down between the oil filter and the regulator and zip tied it and let it hand down about 1/2" below the motor. Works like a charm.
Sea Foam is a good product, works well, and we carry that in the retail area here.
As already mentioned, if the brethers are re-plumbed externally, the oil mist from the crankcase vents will not be inhaled by the engine, and will stop most/all of that build up. :)
Scott
Is there any advantage to having the vents hooked up to vacuum? I got all excited reading a post on HTT and bought a catch can for like 20 bucks that is built for carts but would work fine for our application as well.
Just a suggestion, cylinder stud protectors. Even the slightest movement of the piston against the threads of the studs will damage the rings
Yes, you are correct. We fitted new CP pistons after this pic was taken....this was during tear down before putting my 98" kit in. The original pistons are a ashtray and and paper weight now.....
Just the standard regular sea foam that they sell in the auto parts store. I've only seen one being sold.
A negative pressure under the piston is what NHRA Pro Stock cars did (still do?) via a pump.
Us and others fooled with that(w/o the use of a pump, mind you) back in the early '90's when racing ECRA/AHDRA w/o any good results.
Scott
There are two types of sea foam a bottle and it also comes in an presurised can. this is what I use it works for a lot of thing including as a lubricant.i use it in my nail guns all the time.i use it like Greeks use windex.lol
1 - 19 of 19 Posts
