1 - 20 of 20 Posts
I'm thinking of buying the "Extended" Floorboards and the Brake Pedal for my 2004 Road Glide. I am 6' 3" and I have a 35" inseam. I have found the Glide to be a little cramped and thought this might help.
Anybody have any experience with these Harley parts?
I have a bundle of "Points" from the dealership that comes to around $250.00 and thought this would be a great addition.
Check out tall boys cycle floorboard relocation brackets tallboyscycles.com or kuryakyn floorboard relocation brackets, 1" out & 1" forward, can also be used with Harley extended floorboards.
I also recommend walters workshop extended shifter arm waltersworkshop.com & softbrake.com or
E-ZBrake.com for extended brake levers.
I have the kuryakyn board relocators. Love them. I'm considering the Es-brake as well
a little more roomy....
I used the Kuryakyn floorboard brackets (moves 'em 1" up & 1" out), the Kuryakyn extended shift lever and the brake lever. I'm 6'6" and wear size 14 boots. The Kuryakyn brake lever puts the pad further out and lower. To install it I had to loosen the lower fairing support in order to rotate the lever onto the shaft. Just for comfort I also permanently removed the vents to prevent my toes from hitting them. I also removed the heel shifter lever to make room for my big feet! If you use the Kuryakyn heel shift eliminator it also moves the shifter out a little. It works for me.
Kury 1 and 1 on the floorboards and the kury extended break pedal. Don't have any before pics to do an exact comparison but you can compare to your position. Both work just fine with lowers.
If you want a bad ass look and lots of room for your feet then consider the banana boards. I put them on my RG CVO Custom and love them.Rode 2,700 miles in 7-days through the Black Hills and having the room to move your feet around for the long run days is a real plus. Also bought the banana board passenger floor boards and the old lady loves them.
Reactions: widerider03
What length did you put on? I want some!!
2019 RGS
Another one for the kuryakyn 1 + 1s. Love them. I want the kury brake lever too.
One thing I did was add a thicker washer on the front mount so it didn't flop.
1 - 20 of 20 Posts
