1 - 11 of 11 Posts
I have the Baker that Kenny listed above on my '12. It's been in two bikes now and still looks great.
Sent from Tapatalk. probably while pooping.
I’ve run Softbrake extended heel shifters, and run Harley’s extended heel/toe shifters. One inch extended in either direction, 2” total.
On my latest bike I am running stock heel/toe shifters, and I wear size 14 boots.
The key is adjusting the shift levers on the splines, AND adjusting the shift linkage so you can lower the levers just high enough to not hit the footboard with the heel shifter, and not have to jack your boot up in the air to down shift on the toe shifter.
Tire Wheel Bicycle tire Automotive tire Automotive lighting
1 - 11 of 11 Posts
