1 - 4 of 4 Posts
I had heard that the RGU came factory with a CB and I have dual antennas on the tour pack of my '12, however when I scroll through the options on my radio it does not show yet iPod does, did the previous owner change things up or did it just not come with a CB? If it has one and the settings got changed how do I change it back? If it doesn't have one, is it possible to find a CB that utilizes the controls on the handle bars and the sound comes through my helmet via the plug on the gas tank for my helmet? All of this while saving $1400 from not buying a new one from the dealer
The CB module and iPod module can coexist if they are the HD versions. I yanked my CB so long ago, I don't even remember how you're supposed to access it on the head unit.
You can pull the outer fairing and look at the back side of your head unit. The CB module will be mounted on top. It will be marked CB or something similar.
You hit the comm button and that gives you option that turns cb off and on
Perfect, thank you. Do you know if there's a PDF version of the manual so that I can figure out how to program it?
1 - 4 of 4 Posts
