1 - 4 of 4 Posts
Hi boys, starting to warm up in the northeast, and looking to start the install of the goodies I bought over the winter. I have a set of J & M speakers, HID headlights (from the group buy) klock werks 8" (came from the seller in a madstad box, ha!).
My question is, should I pull the fairing and do it all at once? Or can I just toss the windshield on for now without problems opening up the fairing later? I'm not really a wrencher, and will get some help from my cuz that is a mechanic when we open her up.
Thanks in advance.
DJ Terry Moran
Windshield can go on with no problems its just the 5 screws and well nuts. Then do the hid and speaker install at your leisure. I think you'll be surprised how easy the install of them all will be.
X2 Windshield is easy. So are the other two once you take the outer fairing off which is also pretty easy. Putting it back on can be a little tricky, but much easier if you take the headlights out. Several instructional videos on the forum and probably on you tube. Good luck.
Checking out the led strips mod now and really like it, so I'm going to do that as well.
DJ Terry Moran
1 - 4 of 4 Posts
