1 - 20 of 26 Posts
I couldn't find much on this topic. I'm looking to see if anyone has installed this on their own and if it's worth it. Of course HD wants about 2 hours for install. I have lowers installed along with the 21 inch wheel so I'm wondering with the added area these take up if it would be worth the investment.
I had a Ultracool on my 12 and It didn't take up much more space.... And I did have lowers on it... If I remember correctly it was around 5 bills...
On my 2008 I had a jagg 10 row fan assisted oil cooler and pretty much never went over 245 degrees.
Just had an Ultracool 2.0 with Twin Fans on it installed a couple weeks ago, fans kick on around 200 degrees & oil temps run between 230 - 240 consistently. This is on my 2009 FLTRSE3 with a 110 motor.
Well worth it, especially if you have done anything to the motor. I installed the ultracool reefer on mine. With a 124" it's a necessary thing.
I just put 1 on the other day.Took about 1/2 hour with the cover they say doesn't fit...it does.Then a trip to American Harley where they flashed it .....for free!Best dealership around these parts.I don't have your wheel setup so can not speak for that .I also didn't change the hoses ...they are new anyway.
Pags63 - When you installed the fan is there a power connector already in that area for the fan? I was at dealer today and they gave me a price of $550 installed so I want to install it myself and was wondering if the power connector is already in that area.
The dealer wanted $200 to install the fan assisted oil cooler. You can do it yourself in about thirty minutes. First I went to the dealer and had them activate it in the ECM. (Literally took two minutes, charged me $45 nearly $60 with tax. They are losing a customer) while there I bought a qt of oil. My bike is new so I didn’t replace the hoses. That eliminates the need to remove the exhaust. First remove the plastic cover there are two pins that press threw grommets at the bottom and two slots that hook at the top. (Didn’t even have to remove the Lower Fairings)then I cut the clamps loose very carefully with a dremal cutting wheel. Cut the center of the raised crimp and it pops loose stretch and remove. Second I used channel locks and a rag to work the hoses loose. You will loose almost half a qt of oil. Third I used a offset ratcheting screwdriver with a T27 screw tip to remove the mounting screws there’s only about 1-1/8 of clearance on the break side. Fourth with the hoses loose and screws out there is a T that secures the top of the cooler. Lift up wiggle a little til the T finds the slot and it will come off. Fifth plug in the electrical connecter for the fan in the mating plug that is in the center of the frame already on the bike at the bottom of where the cooler sits. Then clip the T in the slot replace the T27 mounting screws connect the hoses. Replace the trim cover. Replace the 1/2 (+-) qt of oil and your done.
I bought mine at BoardTracker for $272
What year bike is this you’re referring to? I see an OG Roadie in your avatar but that doesn’t sound like instructions for that bike.
Did you buy an ultracool reefer at Boardtracker?
Wow $200, they were really trying to hose you on that install. I thought about buying it online and installing it myself to save a few bucks, but my dealer only charged me ½ hour labor ($53), which is their minimum charge and I would have paid that for them to activate it. Plus, by having them provide and install, it is covered under my factory warranty which to me was worth what I would have saved.
It’s a 2018. And it’s the Harley Fan assisted oil cooler. The bike really likes it. I put lowers on and I’ll leave them on all year confidently with this cooler
I agree I would have done the same thing. Sounds like you have a reasonable dealer
That was my 2012 in the picture. I really liked the way that bike looked and knew it inside and out. But this 2018 is growing on me. Lol
i installed the ultracool reefer cooler on my bike a couple years ago. i like it. the temp never goes past 230ish on a hot day. installing it can be a little tricky but it wasn't too bad. as far as cost, i think i paid 250/300 for it online. considering the HD cooler is $300 i figured for the same price or slightly less id go with the ultracool fan assisted cooler. no regrets here. as far as price to have it installed youll probably get 5 different prices from 5 different places. if you have the ability to install it then save yourself some money and do it yourself
Reactions: till66
I bought the Jagg fan assisted oil cooler. I bought the first one they sold when it was first released. Marv at Jagg had to email me the instructions because they weren't printed yet. It has worked perfectly and done a great job for 7 years.
I plan on putting the Harley Fan Assisted Cooler on mine. Currently Boardtracker has it for $269.00 (Harley Catalog its $329.95 wtf). Also, my dealer wanted 2-3 hrs to put it on, I told them forget I'll do it myself. They said for it to be under warranty they would need to install it. I told them for what they were going to charge me for labor I could buy another one if the first one fails and still be ahead. F-ing Harley and their gouging prices. Love the product hate all the other bullsh**.
I hate to break it to you bro, but you’re still gonna have to take it to the dealer and pay them to activate it with their digital tech too,l otherwise it won’t work. I agree they are ripping you off on what they are charging to install it. My local dealer only charged me 30 minutes labor to install and program it which is their minimum charge.
Yes I know the dealer needs to activate and it will cost me their min charge also (already had the conversation with them).
1 - 20 of 26 Posts
